Engine and Pump
Aller à la page: <  1, 2, 3
eTraxx
MessagePosté le: Ven 20 Mai - 20:21 (2011)    Sujet du message: Engine and Pump Répondre en citant
Christophe. Here is the link to the company .. http://www.shapeways.com/
The printers are actually located in the Netherlands .. so much closer to you then to me!
There are a bunch of different kinds depending on the material you have the parts printed in. Here is a link to the materials that Shapeways offers .. http://www.shapeways.com/materials/
I am using the one "Frosted Ultra Detail" - http://www.shapeways.com/materials/frosted_detail
That's because this material has the best resolution .. look under "Design Rules" on that last link .. Frosted Ultra Detail has a Minimum wall thickness of 0.3mm and a Minimum detail thickness of 0.1mm. There are a variety including stainless steel.
The Frosted Ultra Detail .. FUD .. is an acrylic. My understanding is that the printer sprays an acrylic polymer much like an ink jet printer. Then a UV (Ultra Violet) light hardens that layer of plastic. The printer head then moves up (how far depends on the printer) and sprays another layer. This continues until the part is printed.
Edward Traxler
MessagePosté le: Ven 20 Mai - 20:21 (2011)    Sujet du message: Publicité
MessagePosté le: Sam 21 Mai - 09:57 (2011)    Sujet du message: Engine and Pump Répondre en citant
But if I understand you made the drawing on Sketchup and you send it to them Question
eTraxx
MessagePosté le: Sam 21 Mai - 11:26 (2011)    Sujet du message: Engine and Pump Répondre en citant
That's correct. Let me think about it .. drink some coffee (it's morning here) and I will write up a tutorial on the process. How's that?
Edward Traxler
MessagePosté le: Sam 21 Mai - 11:53 (2011)    Sujet du message: Engine and Pump Répondre en citant
Okay great
MessagePosté le: Dim 4 Mar - 19:34 (2012)    Sujet du message: Engine and Pump Répondre en citant
I've found a excellent page with a lot of plans of different steam engines
http://www.john-tom.com/html/SteamPlans.html
MessagePosté le: Dim 4 Mar - 20:33 (2012)    Sujet du message: Engine and Pump Répondre en citant
excellent Okay
MessagePosté le: Aujourd’hui à 09:38 (2018)    Sujet du message: Engine and Pump
Page 3 sur 3
