Engine and Pump
Aller à la page: 1, 2, 3  >
eTraxx
MessagePosté le: Jeu 10 Mar - 14:13 (2011)    Sujet du message: Engine and Pump Répondre en citant
I model in O scale (On30) and I am building a pump house. I needed an engine and pump. I found a photo of a double-plunger pump driven by a gas engine. This became my guide. I wanted to make something that generally resembles the machinery. Since this will be sitting inside the pump house and visible only through windows and doors it is to more like suggest the machinery then be a fine scale model.
I used Evergreen styrene to construct the body of the engine and pump. The red piston cylinder is cut from an electrical connector ...
Worked continued with the pump. I used Tichey nut/bolts ...
This is the pump manifold. The flange on top will be where the air cylinder mounts. On the ends are the intake and outlets for the water. One side will be capped off while I will run pipe from the others.
Here, I am nearing completion. The gear is a slice of a gear from a VCR. The center with the 'arms' is a clock gear with the teeth filed off. To weather the machinery I used the hair-spray technique.
Finally, some photos of the 'mostly' completed machinery. I added a clutch between the pump and engine. Some small parts will be added later .. piping, intake and exhaust and so on. The small gears are from alarm clocks. The flywheel is made from the tire of a HO locomotive with the flange filed off and arms made from styrene.
For a size comparison, the machinery with an American penny ..
Edward Traxler
MessagePosté le: Jeu 10 Mar - 14:13 (2011)    Sujet du message: Publicité
starbuck
MessagePosté le: Jeu 10 Mar - 18:25 (2011)    Sujet du message: Engine and Pump Répondre en citant
MessagePosté le: Jeu 10 Mar - 19:00 (2011)    Sujet du message: Engine and Pump Répondre en citant
From a guy who loves industry machine gears etc...
What kind of complex this pump house will be implanted Question
eTraxx
MessagePosté le: Jeu 10 Mar - 19:22 (2011)    Sujet du message: Engine and Pump Répondre en citant
Christopher. I have the build on my forum -> http://www.etraxx.com/phpbb3/viewtopic.php?f=24&t=32
I am in fact working on it today and will be posting updates. Here is an earlier version just sitting on my layout (not glued yet)
Since that time when I made the pump and engine I added between them a clutch. That made the machinery too long for the old pump house so I am expanding it. Here is my Sketchup drawing of what is to be ..
Edward Traxler
MessagePosté le: Jeu 10 Mar - 19:53 (2011)    Sujet du message: Engine and Pump Répondre en citant
That's excellent Edward I really love the texture on this building also your rocks around looks terrible Smile
Pour tout le monde voici comment Edward fait ses rochers à méditer Arrow http://www.etraxx.com/phpbb3/viewtopic.php?f=23&t=31
eTraxx
MessagePosté le: Jeu 10 Mar - 20:04 (2011)    Sujet du message: Engine and Pump Répondre en citant
Ahh .. my foam rock tutorial. I was amazed at how easy it was to make these rough rocks so simply ..
Edward Traxler
MessagePosté le: Dim 13 Mar - 14:44 (2011)    Sujet du message: Engine and Pump Répondre en citant
Very interesting project, add to my favorites Smile
eTraxx
MessagePosté le: Dim 13 Mar - 21:06 (2011)    Sujet du message: Engine and Pump Répondre en citant
A little progress on the pump house. I am working on some small things - the 6" gate valves while waiting for supplies to come from Plastruct (I ordered pipe fittings).
Here is a good view of the cement block extension. If you look back at the earlier version of the pump house you can see that much of the lower portion will be hidden by rock .. so I did not waste the cement block material on that. I forget to add window sills so I am now thinking how to do this. I also need to add stains from water and dirt on the cement wall.
When the extension was added the old wall was broken and removed. You can also see that there is a 'dog leg' in the rear wall where the cement block meets the brick. This is because the brick and the cement wall do not come out even with the mortar joints. This kind of compromise is common I think. Is that term used in France? .. 'dog leg' .. it means where the wall jogs to the right.
Edward Traxler
MessagePosté le: Dim 13 Mar - 22:09 (2011)    Sujet du message: Engine and Pump Répondre en citant
Really nice texture, weathering, looks real
eTraxx
MessagePosté le: Mar 15 Mar - 16:42 (2011)    Sujet du message: Engine and Pump Répondre en citant
I am planning to plumb the structure. I have some pipe fittings coming from Plastruct for 1/8" tubing (which scales about half-way between 5" and 6" pipe in O scale). In the meantime, I have a need for some ~6' Gate Valves. I ordered some #000-120 screws which came in yesterday so I have everything except the hand-wheel. I have some HO rail cars around somewhere .. I am thinking that the brake-wheels might work.
Edward Traxler
eTraxx
MessagePosté le: Mar 15 Mar - 23:02 (2011)    Sujet du message: Engine and Pump Répondre en citant
Started assembly .. (those are mini-clothespins)
Edward Traxler
eTraxx
MessagePosté le: Mer 16 Mar - 01:08 (2011)    Sujet du message: Engine and Pump Répondre en citant
Now comes the part where you wait patiently for the cement to completely set up. I still need to add the two supports between the body and the .. collar/packing. Still haven't found the HO railcars I have .. was hoping I can use the HO brake-wheel for the gate valve hand-wheel.
Paint .. hmmm. Wonder if modulation at this size would work? Smile
Had to use two #000-120 screws for each gate valve since .. I DID find #000-120 All-Thread .. but at $55 for 12" .. I can live with the two screws and any slight misalignment .. Ha
Edward Traxler
eTraxx
MessagePosté le: Mer 16 Mar - 03:28 (2011)    Sujet du message: Engine and Pump Répondre en citant
Well .. the way I see it .. gate valves should scale up and down. The body, stem, bolts .. would all basically scale up or down as pipe size changes. SO .. these could be 20" gate valves!
Anyhoo. Pretty much finished. Let the cement set overnight. I will slightly radius the tops of the braces where they attach to the screw support (whatever that thing is .. screw collar?) and lightly sand (600 grit) any 'dangles' of styrene.
I will cut off the valve stem on two of the gate valves as these represent a 'rising-stem' gate valve and with the valve opened the stem should protrude about 1/8" (6" valve). When closed the stem will barely protrude past the hand wheel. That means I need handwheels first .. then 'snick' off any excess stem.
Gotta admin .. pretty happy with how they came out. Looking forward to painting them.
Edward Traxler
MessagePosté le: Mer 16 Mar - 22:01 (2011)    Sujet du message: Engine and Pump Répondre en citant
Nice work, Okay Okay
eTraxx
MessagePosté le: Mer 16 Mar - 22:17 (2011)    Sujet du message: Engine and Pump Répondre en citant
Thanks Jean.
Here's the finished gate valves. Mounted on toothpicks Smile .. one is open (stem extended) and the other two are closed.
Edward Traxler
MessagePosté le: Aujourd’hui à 15:54 (2018)    Sujet du message: Engine and Pump
Page 1 sur 3
