Consolidated Nickel Mines Layout
MessagePosté le: Sam 31 Déc - 22:47 (2016)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Dear modeling friends.
We have taken the section n.1 of our layout to our living room, to install the auger dosing units. For us, city-dwellers, space is at a premium, and we must work in the available space.
After careful machining and adjustments, we managed to match the flange of the silo and that of the new dosing unit. Four 1.2-mm bolts keep the pieces together.
https://www.flickr.com/photos/91867668@N07/31169694014/
We load the ore, and the operational trial begins:
https://www.flickr.com/photos/91867668@N07/31972287676/
Unbelievably, everything works. With the auger at 20 RPM we obtain a stable mass output 2 times higher than that of our older rotary-cone unit.
https://www.flickr.com/photos/91867668@N07/31861761052/
Meanwhile, as can be seen in the previous photo, we have modified the centering hopper (the one that distributes the material onto the conveyor belt), to accommodate the higher mass flow. At 1.5 cm/second belt speed, we obtain a uniform, spillage-free movement of the ore on the belt.
https://www.flickr.com/photos/91867668@N07/31972339016/
The silo n.2 and its conveyor are now operating beyond their limits. In some minutes, we overfill the silo n. 2, and we have to stop the belt no. 1. The next step will be the installation of another auger at the silo n.2. In parallel, the swiveling hopper that loads the cars has been already modified to accommodate the larger flow.
Meanwhile, we have improved the structure of the platform at the top of the silo n. 1. The platform stays on top of a flange that incorporates the bearings of the shaft of the old dosing cone unit. The flange was kept in position by 3 miserable self-tapping screws; we decided to solder in place 6 solid brackets with ISO 2-mm tapped holes.
https://www.flickr.com/photos/91867668@N07/31635760690/
The back of the upper platform shows the new wiring that feeds the LED lighting:
https://www.flickr.com/photos/91867668@N07/31861705432/
The upper silo platform is fastened to the flange with its screws, all the pieces are in position, all the wiring is connected, and it is time for a longer trial, interrupted by the continuous overfilling of the silo n. 2. One last photo of the section under its own illumination creates a suggesting night-shift atmosphere.
https://www.flickr.com/photos/91867668@N07/31893082121/
We will keep you posted.
Happy New Year from Milan!
Mad Doc & Nickel Queen
MessagePosté le: Sam 31 Déc - 22:47 (2016)    Sujet du message: Publicité
MessagePosté le: Dim 1 Jan - 05:25 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
last picture is amazing looks like a futuristic extraction mine on Mars and can be used as film decor
great job as usual
happy new year from my lost place here to you and your wife Okay
MessagePosté le: Dim 1 Jan - 14:19 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Very nice work
Happy new year to both of you.
MessagePosté le: Sam 7 Jan - 20:40 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Hallo Christophe, hallo Jean.
We have completed the installation of the new dosing unit on our silo no. 2, and we have finally carried out the complete commissioning trial of our machinery.
Here is a view of the belt n.2 and the swiveling hopper
https://www.flickr.com/photos/91867668@N07/32022786611/
As expected, the belt conveyor no. 2 can now handle the full flow of ore originating from the conveyor no. 1.
https://www.flickr.com/photos/91867668@N07/32102784896/
Here is a detail of our shaftless auger dosing unit no. 2. We will do a serious weathering of all the metal; after the modifications/soldering/machining, everything is unnaturally clean. Also, the auxiliary non-functional pieces, cowlings, embellishments, etc. must be re-installed.
https://www.flickr.com/photos/91867668@N07/32022821731/
https://www.flickr.com/photos/91867668@N07/32022937191/
During this test, we identified the “standard” conditions for prolonged loading operations (in terms of RPM of dosing units and linear speeds of belts).
Eventually, we did a photo session. As reference, we took these shots with long exposure (5 to 15 seconds) and a massive tripod, 200 ISO setting and intermediate f-settings to have some depth-of-field. The illumination came from a hand-held LED lamp and the own lighting of the layout.
https://www.flickr.com/photos/91867668@N07/31331340263/
https://www.flickr.com/photos/91867668@N07/32022855101/
https://www.flickr.com/photos/91867668@N07/32141385235/
https://www.flickr.com/photos/91867668@N07/32022865251/
https://www.flickr.com/photos/91867668@N07/32022890071/
Happy new year again, and good railroading.
MessagePosté le: Sam 7 Jan - 22:06 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Wonderful job
the night shots are incredibles
I love especialy the work on the safety ladder and handrails because it's not so easy to make even in HO
Happy new year
MessagePosté le: Dim 8 Jan - 13:31 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Nice improvement, and very nice work Okay Okay
Like the pics too
MessagePosté le: Sam 14 Jan - 22:45 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Chers amis modélistes.
Notre travail continue. Nous avons terminé la partie mécanique, nous avons réinstallé la végétation détruite pendant les travaux, installé a nouveau les pièces esthétiques, et faite la première couche de weathering.
Nous avons pulvérisée sur les structures en métal et sur le paysage un wash glycérophtalique à base solvant, gris foncé matte, diluée 1/20, avec un aérographe 0.2 mm. Ca simule bien la couleur de la poussière de minerai.
Pendant le séchage de la couche, nous avons appliqué avec un pinceau souple un pigment iron oxide sur certains points de la structure, pour simuler la rouille (mais, des que notre structure est construite en acier, elle développe elle-même, âpres quelques mois, de la vraie rouille). Jusqu'à un certain niveau, la vraie rouille est très réaliste, mais il faut se méfier de la rouille sur les parties mécaniques, ou sur les tôles acier de très faible épaisseur. Donc, il faut toujours avoir a portée de main du WD 40, des cotons-tiges, e du papier abrasif très fin pour des petites interventions antirouille.
Ces photos sont plus lumineuses de la réalité, mais ca est un effet du mauvaise éclairage – trop direct - que nous avons utilisé (et notre manque de patience pour corriger les bizarreries de notre camera. En réalité, l’atmosphère de notre paysage minier est plutôt sombre.
https://www.flickr.com/photos/91867668@N07/32309643585/in/dateposted-public…
https://www.flickr.com/photos/91867668@N07/32270263646/in/dateposted-public…
Ici, en détail, un petit divertissement pour les fous (nous deux). Pas encore satisfaits des complications, nous avons décidé d’installer des ouvertures fictives de ventilation sur les capots des drives de nos doseurs à vis.
Nous avons réalisé des minuscules pièces coupées à partir de la toile d’acier fin, et des fines gouttières, coupés avec la fraise et disque de coupe ultrafin en carbure de silicium, et nous avons tout installé sur les capots. A noter, ces gouttières ont une section de 0.8 mm, et épaisseur de 0.15 mm. Nous ne sommes pas arrivés à passer en machine de la tôle plus mince que ca.
https://www.flickr.com/photos/91867668@N07/32270271786/in/dateposted-public…
https://www.flickr.com/photos/91867668@N07/32270278826/in/dateposted-public…
A continuer.
Meilleurs vœux de Milan
MessagePosté le: Dim 15 Jan - 19:24 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Ils sont fous ces Italiens, mais j'adore ce qu'ils font tous les deux...
ENCORE !!!!
Okay Okay Okay
MessagePosté le: Dim 15 Jan - 22:19 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Comme on dit chez nous c'est Nickel (parfait) Okay
MessagePosté le: Lun 16 Jan - 20:36 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Citation:
Lol! je bisse! Okay
MessagePosté le: Sam 11 Fév - 15:54 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
We are completing some aesthetic modifications to our layout. First, we decided to add another railing to the walkway of our rotary dumper. All these new parts are sub-assemblies that we build outside, to be installed with minimal, or no modification, to our existing structures.
The railing is a latticework of 0.5-mm steel wire, on a base made from a 2 x 2 mm strip of hardwood. We machined the back of the strip to match the existing profile of the side of the existing walkway (which is made of steel).
https://www.flickr.com/photos/91867668@N07/32684103662/
This is the railing after machining, finishing, provisionally installed. The “new” railing is facing the hoppers, while the “old” was already in position, facing outside. After weathering, we installed the part.
https://www.flickr.com/photos/91867668@N07/32837549205/
https://www.flickr.com/photos/91867668@N07/32022856863/
The reailing has two danger lights at the ends of the walkway. In the prototypical world, the walkway is manned only during maintenance, and never during operations. Our lights are 2.6-mm LEDs, installed onto steel poles. We always grind, with 600-grit paper, the housings of our LEDs, to obtain non-directional, diffused light.
We did a photo session of the completed dumper module; in most of the photos, the only lighting comes from the on-board array of LEDs. In a couple photos, we added subdued cold-tone illumination from a dimmable photo lamp.
https://www.flickr.com/photos/91867668@N07/32796296106/
https://www.flickr.com/photos/91867668@N07/31994496514/
https://www.flickr.com/photos/91867668@N07/32022798143/
https://www.flickr.com/photos/91867668@N07/32796250446/
Further, we decided to install other danger lights inside the fenced area of the hoist of our mineshaft. Our hoist is easily removable for maintenance (2 screws from below). We took out the part, installed the 4 poles, and did the wiring. We re-weathered the entire hoist, since drilling, touching and machining had worn off the previously applied patina.
https://www.flickr.com/photos/91867668@N07/31994542724/
https://www.flickr.com/photos/91867668@N07/31994445264/
For the same reason, we re-weathered other parts that recently underwent scheduled maintenance:
The hopper/diverter unit at the base of our mineshaft
https://www.flickr.com/photos/91867668@N07/32796229496/
The underground silo/dosing unit/conveyor assembly, which loads the hopper/diverter and the 2-way skips
https://www.flickr.com/photos/91867668@N07/32713810121/
When this unit is installed, only the conveyor is visible. The silo and the dosing unit remain hidden behind the underground landscape. In the prototypical world, this conveyor would have had a length of hundreds of meters. In H0 scale, it would exceed our transportation capabilities :-)
Best wishes from Milan
Mario & Bice
MessagePosté le: Dim 12 Fév - 13:18 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
As usual, a clean work and dramatic night pics.
MessagePosté le: Sam 8 Avr - 10:23 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Chers amis,
Veuillez noter que le réseau Consolidated Nickel Mines Co. sera exposé à TRAINSMANIA 2017 – Lille, le 28 – 29 – 30 avril.
Ici le lien au site de l’exposition :
http://www.trainsmania.com/les-reseaux/#item-37
Nous vous attendons!!!
MessagePosté le: Lun 8 Mai - 19:59 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Dear modeling friends,
We exhibited at Trainsmania 2017 in Lille, on 28, 29, and 30 April. Double thumbs up to the organizers (LR Presse, publisher of the Loco Revue magazine). Unfortunately, we were the only exhibitor to carry the flag of American model railroading.
The show took place at the Grand Palais of Lille; logistics and hall access with materiel was top-level, the halls were heated and lit also during the day of installation, and in the evening of dismantling. Catering and accommodation for exhibitors was also taken care of by the organizers, as in the other EU leading model railroading fairs (and this IS definitely a leading fair), and on Saturday 29, even a cocktail party for the exhibitors was organized.
https://www.flickr.com/photos/91867668@N07/34507489975/
During the 3 days of the show, we had been swamped by a colossal flow of visitors. Many of them were “real” model railroaders; they asked interesting questions. We had already met some of them at previous fairs. Some visitors had also built, or were building, mining layouts, and were eager to get (and copy...) information on operational conveyor belts. In fact, we did not have much time to see the other layouts. And, as usual, after a show of this caliber, we were dead tired.
https://www.flickr.com/photos/91867668@N07/33697247763/
https://www.flickr.com/photos/91867668@N07/33664748554/
https://www.flickr.com/photos/91867668@N07/34466185656/
https://www.flickr.com/photos/91867668@N07/33665089904/
The only relatively free time was in the morning before opening time, but we also had to do the usual preparations, setup, and verifications.
https://www.flickr.com/photos/91867668@N07/34376787901/
https://www.flickr.com/photos/91867668@N07/33664974434/
This was the first time when our new auger dosing units have been operated in a modeling show, clocking 25-plus hours of continuous operation. As seen in the previous commissioning tests, the new units, compared to the old rotary-cone units, have improved flow uniformity and throughput.
https://www.flickr.com/photos/91867668@N07/34346459692/
https://www.flickr.com/photos/91867668@N07/34376616561/
https://www.flickr.com/photos/91867668@N07/34465854956/
As maybe seeable in the photos, we have added further (rather heavy) weathering to our steel structures, due to the fact that the lighting conditions at exhibitions tend to create unpleasant reflections on the metal. Especially, we airbrushed our rotary dumper section.
https://www.flickr.com/photos/91867668@N07/34346572392/
https://www.flickr.com/photos/91867668@N07/34121713080/
https://www.flickr.com/photos/91867668@N07/34465996456/
https://www.flickr.com/photos/91867668@N07/34466019066/
https://www.flickr.com/photos/91867668@N07/34466158296/
Some videos of Trainsmania 2017 begin to appear in the Internet, and some blogs have also mentioned our contraption
https://www.youtube.com/watch?v=CyD93INV7Uc
(skip to 5 minutes 30 seconds)
https://www.youtube.com/watch?v=KHa04n7zi8Y
http://us.leforum.eu/t11904-trains-mania-expo-de-LILLE.htm?start=15
(Page 2, Sunday 30 April, Tuesday 2 April, and later.)
From our side, after such a satisfying overdose of modeling, we will not touch our layout for a while.
P.S. the team of LR Presse has extensively filmed and photographed the layouts at Trainsmania 2017. From what we heard, they will prepare a special edition of their magazine with the reportage of the fair, and a DVD.
MessagePosté le: Mer 10 Mai - 05:33 (2017)    Sujet du message: Consolidated Nickel Mines Layout Répondre en citant
Thank you for this report and videos
your layout is unique Okay
Well after your pause maybe a Nickel Smelter Idea Smile
MessagePosté le: Aujourd’hui à 21:45 (2018)    Sujet du message: Consolidated Nickel Mines Layout
Page 2 sur 4
